StarTech.com 8 Port Low Profile PCI Express RS232 Serial Adap...
StarTech.com 8 Port Low Profile PCI Express RS232 Serial Adapter Card w/ 161050 UART
Key features
  • Breakout cable design uses only 1 PCIe slot to add 8 serial ports
  • Included low and full profile brackets fit almost any PC case
Product codes
Add 8 RS-232 serial ports to your computer through a single low profile PCI Express slot. The PEX8S1052 8 Port Low Profile PCI Express RS232 Serial Adapter Card w/ 161050 UART lets you add 8 RS-232 serial ports to your computer through a single low profile PCI Express slot.
Supporting data rates up to 460.8 Kbps, the PCI express serial port card offers a high performance 16C1050 UART and a large 256-Byte transit/receive FIFO buffer that work together to provide high-speed serial communication while reducing the overall load on the system CPU.
Suitable for most standard computer chassis, the 8 port serial card offers a low profile/half-height design and includes an optional full-height bracket. The included break-out cable uses a single connector on the card to deliver 8 ports, avoiding crowded connections that can occur with fixed/static ports.
StarTech.com 8 Port Low Profile PCI Express RS232 Serial Card w/161050 UART - serial adapter
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express
Ports
RS-232 x 8
1.8 cm x 17.5 cm x 5.6 cm
75 g
Cabling Type
Serial RS-232
Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Linux Kernel 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 8 Port Lo...
