StarTech.com 8 Port Native PCI Express RS232 Serial Adapter C...
StarTech.com 8 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART
£151.34
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High Performance Dual Channel Oxford 950 UART
  • Less load on the CPU
  • Native single-Chip, single lane PCI Express
  • Type: Serial adapter
  • Compatibility: Mac, PC
  • Interface: PCI Express x1
  • Stock Status: In Stock
Product codes
This PCI Express based serial adapter card allows you to turn a PCI Express slot into eight RS232 (DB9) serial connections. The adapter card is based on a native single chip design that allows you to harness the full capability of PCI Express (PCIe) - providing optimum reliability and speed, and reducing the load applied to the CPU by as much as 48% over conventional serial cards. The RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista, Linux Kernel 2.6.11 and up, as well as MAC OS 10.4 and above.
Product Description StarTech.com 8 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART - serial adapter
Device Type Serial adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express x1
Ports RS-232 x 8
Dimensions (WxDxH) 2 cm x 9 cm x 6.5 cm
Weight 58 g
Data Link Protocol RS-232
System Requirements Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows 2000 / ME / XP, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 3.5.x - 4.11.x LTS versions only
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 8 Port Na...
£151.34
