StarTech.com 8 Port Unmanaged Industrial Gigabit Power over E...
StarTech.com 8 Port Unmanaged Industrial Gigabit Power over Ethernet Switch - 802.3af/at PoE+ Switch
£256.84
Delivery:
Standard: 1-3 working days
  • Type: Gigabit Ethernet
  • Ports: 8
  • Data Transfer Rate: 1Gbps
  • Managed: No
  • POE: PoE+
Product codes
Connect power and Gigabit Ethernet data to 8 PoE-enabled devices, with 30W per-port output - Wall Mountable. The IES81000POE 8-Port Gigabit Power over Ethernet Switch lets you connect Gigabit Ethernet and power to up to eight PoE-enabled devices, or a mixture of PoE and non-PoE components.
Giving you the freedom to place your equipment in locations where power outlets are not available, this PoE+ switch complies with IEEE 802.3af and 802.3at standards and supplies up to 30 W per port, with a total power budget of 120 W.
A true unmanaged switching solution, the 8 PSE (Power Sourcing Equipment) ports sense whether the connected devices are PoE-ready or require data connectivity only, and also auto-negotiate between 10/100/1000 Mbps network speed and duplex.
The Gigabit Ethernet switch features a sturdy, wall-mountable metal enclosure for durability, and front panel LEDs for quick indication of connection speed and status.
Product Description StarTech.com 8 Port Unmanaged Gigabit PoE+ Switch - 802.3af/at - Wall Mount - switch - 8 ports - unmanaged
Device Type Switch - 8 ports - unmanaged
Subtype Gigabit Ethernet
Ports 8 x 10/100/1000 (PoE+)
Power Over Ethernet (PoE) PoE+
Features Flow control, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, 128KB packet buffer
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
Power AC 120/230 V
Dimensions (WxDxH) 18.8 cm x 11.9 cm x 3.8 cm
Weight 750 g
Colour Black
Localisation North America, United Kingdom, Europe
Designed For P/N: POEEXT1GAT, POEEXT2GAT
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 8 Port Un...
£256.84
