StarTech.com 8 Port USB to RS232 Serial DB9 Adapter Hub
£164.98
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Got more serial peripherals than you do ports? Don't sweat it, StarTech.com has the solution to your problem with the ICUSB2328. It equips your system with eight RS-232 serial ports while taking up only one USB port! Connecting devices like serial modems, GPS receivers, serial printers, and PDAs has never been easier. Perfect for laptop users, the ICUSB2328 is lightweight and compact, so you can take it with you when you're on the go. As well, the unit is fully plug and play compatible, allowing you the flexibility of hot swapping your serial devices without rebooting.
Product Description StarTech.com 8 Port USB to RS232 Serial DB9 Adapter Hub - serial adapter
Device Type Serial adapter
Form Factor External
Interface (Bus) Type USB 2.0
Ports RS-232 x 8
Data Link Protocol RS-232
Data Transfer Rate 115 Kbps
Processor FT232RL - FTDI
System Requirements Linux, Microsoft Windows 2000, Microsoft Windows 98 Second Edition / Windows ME, Apple MacOS X 10.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 8 Port US...
£164.98
