StarTech.com 8-Port USB to Serial Adapter
£312.76
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Converts a single USB port into eight RS232/RS422/RS485 serial ports over USB 2.0 with four modes: RS232, RS422, 4-wire and 2-wire RS485
  • 15 kV ESD protection (Level 4) against noise emissions and electrical voltage surges
  • DIN rail and wall mountable
  • Type: Serial adapter
  • Interface: USB 2.0
  • Stock Status: In Stock
Product codes
Add eight ports supporting three serial protocols, to easily connect serial devices to your computer through USB, with 15kV ESD protection. Add extra COM ports to your laptop or desktop computer, quickly and easily. This USB to RS232/422/485 serial adapter lets you connect to your serial devices through an external USB port.
The versatile serial adapter converts a single USB port into eight RS232/RS422/RS485 serial ports, enabling you to connect, monitor, and control a wide range of serial devices, such as sensors, barcode scanners, and LED signage. It supports four operating modes, including RS232, RS422, 4-wire and 2-wire RS485.
With its rugged IP30-rated metal hub housing, the serial adapter is built to meet the extreme demands of harsh and mission-critical environments. It provides 15 kV ESD protection, which helps to reduce downtime in industrial environments where communications lines are more prone to noise emissions or sudden spikes in voltage.
The serial adapter offers flexible mounting options, with a built-in wall-mounting bracket and included DIN rail mounting kit. It also features a screw-locking host connection plus a screw-locking USB-B connector on the included USB cable, to prevent accidental disconnections.
The serial adapter is equipped with high-speed UARTs, providing fast data rates of up to 921Kbps in RS232/422/485 operating modes.
Product Description StarTech.com 8-Port Industrial USB to RS-232/422/485 Serial Adapter - 15 kV ESD Protection - serial adapter
Device Type Serial adapter
Form Factor DIN rail mountable
Interface (Bus) Type USB 2.0
Ports RS-232/422/485 x 8
Dimensions (WxDxH) 12.8 cm x 21.9 cm x 2.5 cm
Weight 750 g
Data Link Protocol RS-232, RS-422, RS-485
Data Transfer Rate 921.6 Kbps
Processor FT4232H - FTDI
Colour Black
System Requirements Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2008 / 2012 R2, Apple MacOS X 10.9 - 10.13, Linux 2.4.x to 4.11.x LTS versions only
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 8-Port US...
£312.76
