StarTech.com 80x25mm Computer Case Fan with PWM – Pulse Width...
StarTech.com 80x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector
£7.64
18 in stock
Delivery:
Standard: 1-3 working days
  • Type: Case Fan
  • Stock Status: In Stock
Product codes
Add a variable speed, PWM-controlled cooling fan to a computer case. The FAN8025PWM 80mm PWM case fan adds an efficient air cooling solution to computer cases or other enclosures, to keep components running optimally.
With Pulse Width Modulation (PWM) technology, the fan speed can be dynamically controlled by the motherboard, so the fan runs at a speed that suits the operating conditions - lowering power consumption and fan noise when the system is idle, and delivering maximum cooling under full load conditions.
Product Description StarTech.com 80x25mm Computer Case Fan with PWM case fan
Product Type Case fan
Package Content Y-Split cable
Colour Black
Fan Diameter 80 mm
Fan Height 25 mm
Fan Bearing Ever Lubricate bearing
Rotation Speed 800-2500 rpm
Air Flow 9.74-25 cfm
Noise Level 10 - 28 dBA
Power Connector 4-pin fan connector, 4 pin Molex connector
Dimensions (WxDxH) 8 cm x 8 cm x 2.5 cm
Weight 86 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 80x25mm C...
£7.64
