StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with...
StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector
£7.69
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • A dual ball bearing design ensures reliability and longer life
  • Backed by a StarTech.com 2-year warranty and free lifetime technical support
  • Type: Case Fan
  • Stock Status: In Stock
Product codes
The StarTech.com 8cm x 8cm x 2.5cm (3 1/8" x 3 1/8" x 1") PC case fan is an add-in cooling fan designed to fit most computers. It can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components. A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 32 CFM (cubic feet per minute) of air. Power is supplied to the fan using a power tap that is connected to the large LP4 power connector on a PC's power supply.
Product Description StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan w/ LP4 Connector system fan kit
Product Type System fan kit
Fan Diameter 80 mm
Noise Level 27 dB
Features Ball bearing
Product Material Plastic
Dimensions (WxDxH) 8 cm x 2.5 cm x 8 cm
Weight 75 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 80x25mm D...
£7.69
