StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with...
StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with TX3 Connector
£6.01
40 in stock
Delivery:
Standard: 1-3 working days
Key features
  • A dual ball bearing design ensures reliability and longer life
  • Backed by a StarTech.com 2-year warranty and free lifetime technical support
Product codes
The StarTech.com 8cm x 8cm x 2.5cm (3 1/8" x 3 1/8" x 1") PC case fan is an add-in cooling fan designed to fit most computers. It can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components. A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 32 CFM (cubic feet per minute) of air. Power is supplied to the fan using a 3-lead TX3 connector that plugs into the motherboard and allows the system to monitor fan speed and operating status.
StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan w/ TX3 Connector - system fan kit
System fan kit
Fan Diameter
80 mm
Noise Level
34 dB
8 cm x 2.5 cm x 8 cm
75 g
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 80x25mm D...
£6.01
