StarTech.com 8in 15 pin SATA Power Extension Cable
£6.48
45 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by a StarTech.com lifetime warranty
  • Eliminates the need to bend or strain the cable to account for a lack of space
  • Extend the reach from the SATA power connection to your SATA drive connection by up to 8in
  • Length: 20.3cm
  • Stock Status: In Stock
Product codes
Extend SATA Power Connections by up to 8in. The SATAPOWEXT8 8-inch, 15-Pin SATA Power Extension Cable enables you to extend the reach between internal SATA power and drive connections by up to 8 inches. The extension simplifies drive installation by overcoming typical connection limitations, and it reduces the risk of damage to the drive or motherboard SATA connectors by eliminating the need to strain or stretch the cable in order to make the necessary connection.
Product Description StarTech.com 8in 15 pin SATA Power Extension Cable - power extension cable - 20.3 cm
Type Power extension cable
Length 20.3 cm
Connector 15 pin Serial ATA power - male
Connector (Second End) 15 pin Serial ATA power - female
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 8in 15 pi...
£6.48
