StarTech.com 8in 24 Pin ATX 2.01 Power Extension Cable
£5.73
41 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Guaranteed reliability
  • Length: 20cm
  • Type: Motherboard
  • Stock Status: In Stock
Product codes
Extend the length of an ATX power supply connection by up to 8in. The ATX24POWEXT ATX 2.01 Power Extension Cable features one male and one female 24-pin ATX connector, enabling you to extend the length of an ATX power supply connection.
Providing 8-inches of cable length, the ATX24POWEXT allows you to position your internal components as needed within the system case without having to strain the ATX or motherboard connections.
Product Description StarTech.com 8in 24 Pin ATX 2.01 Power Extension Cable - Power extension cable - 24 pin ATX (M) to 24 pin ATX (F) - 7.9 in - ATX24POWEXT - power extension cable - 20 cm
Type Power extension cable
Length 20 cm
Connector Power 24 pin ATX - male
Connector (Second End) Power 24 pin ATX - female
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 8in 24 Pi...
£5.73
