StarTech.com 8in EPS 8 Pin Power Extension Cable
£3.90
Delivery:
Standard: 1-3 working days
Key features
  • Guaranteed reliability
  • Length: 20cm
  • Stock Status: In Stock
Product codes
Extend the reach of your EPS power supply cable by 8in. The EPS8EXT EPS Power Extension Cable features one female and one male 8-pin ATX 12V connector, enabling you to extend the reach of your EPS power supply cable by up to 8-inches and giving you the flexibility to custom build your PC without having to stretch or strain the cable.
Product Description StarTech.com EPS 8 Pin Power Extension Cable - Power extension cable - 8 pin EPS12V (F) to 8 pin EPS12V (M) - 7.9 in - EPS8EXT - power extension cable - 20 cm
Type Power extension cable
Length 20 cm
Connector Power 8 pin EPS12V - female
Connector (Second End) Power 8 pin EPS12V - male
Designed For StarTech.com 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 8in EPS 8...
£3.90
