StarTech.com 8in LFH 59 Male to Dual Female DisplayPort DMS 5...
StarTech.com 8in LFH 59 Male to Dual Female DisplayPort DMS 59 Cable
£16.82
23 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Connect two DisplayPort monitors to your DMS / LFH-equipped graphics card. TheDMSDPDP1DMS-59 to Dual DisplayPortCable allows you to split the video from a single LHF graphics card on to two DisplayPort (DP) monitors.
The DMS to DP Y cable supports high resolutions of up to 4k x 2k (3840 x 2160) with a maximum HBR2 bandwidth of 21.6 Gbps and iscompatible with DMS / LFH 59or DMS / LFH 60graphics cards such as Matrox, NVIDIA, PNY, ATI and HP.
The DMSDPDP1 is designed and constructed for maximum durability - making it a reliable and cost-effective replacement for damaged or misplaced DMS to 2x DisplayPortcables.
Product Description StarTech.com DMS-59 to DisplayPort - 8in - DMS 59 to 2x DP - Y Cable - DMS-59 Adapter - DisplayPort Splitter Cable - LFH Cable (DMSDPDP1) - display splitter - 20.3 cm
Type Display splitter
Features Molded, thumbscrews, strain relief
Length 20.3 cm
Connector 2 x DisplayPort - female
Connector (Second End) DMS-59 - male
Compliant Standards RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 8in LFH 5...
£16.82
