StarTech.com 8in LFH 59 Male to Dual Female VGA DMS 59 Cable
£17.72
Delivery:
Standard: 1-3 working days
  • Type: VGA
  • Length: 20cm
  • Stock Status: In Stock
Product codes
Connect two VGA monitors to your DMS / LFH graphics card. This DMS 59 to dual VGA Y cable allows you to break out one LFH 59 or LFH 60 (DMS 59 and DMS 60) connection on Matrox Qid, nVidia Quadro, and PNY Quadro graphics cards into two high density DB15 female connectors, letting you connect two VGA monitors for a cost-effective dual monitor solution.
Product Description StarTech.com DMS 59 to VGA Splitter - 8in - DMS 59 to 2x VGA - Y Cable - Monitor Splitter Cable - DMS 59 Cable - DMS 59 to VGA Adapter (DMSVGAVGA1) - VGA cable - 20 cm
Type VGA cable
Length 20 cm
Connector 2 x HD-15 (VGA) - female
Connector (Second End) DMS-59 - male
Compliant Standards RoHS
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 8in LFH 5...
£17.72
