StarTech.com 9 Pin Serial Male to 10 Pin Motherboard Header L...
StarTech.com 9 Pin Serial Male to 10 Pin Motherboard Header LP Slot Plate
£3.68
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 23cm
  • Stock Status: In Stock
Product codes
This Low Profile DB9 Serial Slot Plate Bracket adds a DB9 serial port to the rear panel of small form factor/low profile computer, connecting to the host computer motherboard using an IDC10 connector. Please refer to this product's Technical Specifications to ensure compatibility with your motherboard.
Product Description StarTech.com 9 Pin Serial Male to 10 Pin Motherboard Header LP Slot Plate - Serial panel - DB-9 (M) to 10 pin IDC (F) - 9.1 in - gray - PLATE9MLP - serial panel - 23 cm
Type Serial panel
Features Low profile
Length 23 cm
Connector 9 pin D-Sub (DB-9) - male
Connector (Second End) 10 PIN IDC - female
Colour Grey
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 9 Pin Ser...
£3.68
