StarTech.com 90x25mm High Air Flow Dual Ball Bearing Computer...
StarTech.com 90x25mm High Air Flow Dual Ball Bearing Computer Case Fan with TX3
£8.29
10 in stock
Delivery:
Standard: 1-3 working days
  • Type: Case Fan
  • Stock Status: In Stock
Product codes
Keeping a computer cooled is the best way to increase its efficiency and power. A high-airflow fan can ensure that your computer runs smoothly and is kept at a constantly lower temperature than with normal fans. High airflow circulates hot air around the case and exhausts it out the back.
Product Description StarTech.com High Flow Case Fan with TX3 Connector system fan kit
Product Type System fan kit
Fan Diameter 92 mm
Noise Level 33 dBA
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 90x25mm H...
£8.29
