StarTech.com 92x25mm Ball Bearing Quiet Computer Case Fan wit...
StarTech.com 92x25mm Ball Bearing Quiet Computer Case Fan with TX3 Connector
£7.11
22 in stock
Delivery:
Standard: 1-3 working days
  • Type: Case Fan
  • Stock Status: In Stock
Product codes
Keeping a computer cooled is the best way to increase its efficiency and power. A quiet-running fan can ensure that your computer runs smoothly without disruptive, noisy operation.
Product Description StarTech.com 92x25mm Ball Bearing Quiet Computer Case Fan w/ TX3 Connector system fan kit
Product Type System fan kit
Fan Diameter 92 mm
Noise Level 25 dBA
Dimensions (WxDxH) 9.2 cm x 2.5 cm x 9.2 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 92x25mm B...
£7.11
