StarTech.com 92x25mm Dual Ball Bearing Computer Case Fan with...
StarTech.com 92x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector
£6.19
11 in stock
Delivery:
Standard: 1-3 working days
  • Type: Case Fan
  • Stock Status: In Stock
Product codes
This 9.2cm x 9.2cm x 2.5cm (3 5/8" x 3 5/8" x 1") dual ball bearing PC case fan is an add-in cooling fan designed to fit most computers. The PC case fan can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components.
A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 39.35 CFM (cubic feet per minute) of air.
Power is supplied to the fan using a standard LP4 (hard drive power connector) pass through plug.
Product Description StarTech.com 92x25mm Dual Ball Bearing Computer Case Fan w/ LP4 Connector system fan kit
Product Type System fan kit
Fan Diameter 92 mm
Noise Level 32 dB
Dimensions (WxDxH) 9.2 cm x 2.5 cm x 9.2 cm
Manufacturer Warranty 1-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 92x25mm D...
£6.19
