StarTech.com 95mm CPU Cooler Fan with Heatsink for Socket LGA...
StarTech.com 95mm CPU Cooler Fan with Heatsink for Socket LGA1156/1155 with PWM
£18.50
Delivery:
Standard: 1-3 working days
Product codes
The FAN1156PWM CPU Cooler with PWM Cooling Fan for Socket LGA1156/1155 systems provides reliable and efficient cooling for compatible Intel Core i3/i5/i7 CPUs. With Pulse Width Modulation (PWM) technology, the fan speed can be dynamically controlled by the motherboard, so the fan runs at a speed that suits the operating conditions - lowering power consumption and fan noise when the system is idle, and delivering maximum cooling under full load conditions.
StarTech.com 95mm CPU Cooler Fan with Heatsink for Socket LGA1156/1155 with PWM - processor cooler
Processor cooler
Compatibility
LGA1156 Socket, LGA1155 Socket
Heatsink Material
Aluminium
Fan Diameter
95 mm
Fan Height
25 mm
Fan Bearing
Ever Lubricate bearing
Rotation Speed
1000-3000 rpm
Air Flow
65.6 cfm
Noise Level
33 dBA
Power Connector
4-pin fan connector
9.5 cm x 9.5 cm x 4.5 cm
297 g
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 95mm CPU...
£18.50
