StarTech.com 95mm Socket T 775 CPU Cooler Fan with Heatsink
£11.72
48 in stock
Delivery:
Standard: 1-3 working days
  • Type: CPU Cooler
  • Stock Status: In Stock
Product codes
Provide a fan and heatsink cooling solution to any standard socket 775/T desktop CPU. This socket T/775 cooler is designed specifically for the Intel socket 775 (socket T) range of processors, including Intel Core 2 Duo and Intel Core 2 Quad, Core 2 Duo Extreme CPUs.
The CPU cooler features a large aluminum heatsink that maximizes dissipation of the heat around the CPU, as well a low-noise 95mm fan that provides up to 50 cfm of air circulation, helping to keep the CPU cooler for optimized performance.
The socket 775/T cooler/fan offers simple installation, providing tool-less clips for easy connection to the motherboard.
The socket 775/socket T CPU cooler is a dependable, high quality CPU cooling solution.
Product Description StarTech.com 95mm Socket T 775 CPU Cooler Fan with Heatsink processor cooler
Product Type Processor cooler
Colour Black
Compatibility LGA775 Socket
Heatsink Material Aluminium
Fan Diameter 95 mm
Fan Height 25 mm
Fan Bearing Ever Lubricate bearing
Rotation Speed 2800 rpm
Air Flow 49.4 cfm
Power Connector 3-pin plug
Dimensions (WxDxH) 9.5 cm x 9.5 cm x 6.8 cm
Weight 374 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 95mm Sock...
£11.72
