StarTech.com Adjustable CPU Wall Mount
£35.84
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Save space in your work area by keeping your computer out of the way
  • Heavy-duty metal frame holds up to 22 lb. (10 kg)
  • Easy installation with all hardware needed for set up included
  • Stock Status: In Stock
Product codes
Maximize your work space by wall-mounting your CPU for easy access. This adjustable CPU mount is an excellent solution both to save space and extend the life of your equipment. Hanging your computer tower on the wall can help to reduce internal contamination from dust and dirt.
This computer wall mount frees up your floor and desk space, so that you can focus on what's important. The heavy-duty black metal frame is strong and dependable, ensuring your computer is securely fastened.
The adjustable base on the CPU wall mount makes it easy to fit a variety of computers, from 4.8" to 8.3" (122 to 212 mm) in width,. It can hold up to 22 lb. (10 kg). The adjustable straps will ensure your computer is secure.
The open frame design of the CPU mount allows unrestricted access to your computer.
Get up and running quickly. The CPU wall mount is easy to mount, and it comes with all the required hardware and an instruction manual to make installation simple. It mounts easily to walls or other sturdy vertical surfaces.
Product Description StarTech.com CPU Mount - Computer Wall Mount - Adjustable Width 4.8 to 8.3" - wall mount
Product Type Wall mount
Dimensions (WxDxH) 21.2 cm x 23.5 cm x 15.4 cm
Adjustments Width
Weight 2.2 kg
Recommended Use CPU
Max Load Weight 10 kg
Material Steel
Colour Black
Manufacturer Warranty 5-year warranty
Designed For P/N: WALLSTS1, WALLSTS2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Adjustabl...
£35.84
