We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The AR-SFP-10G-LR-ST is an Arista Networks SFP-10G-LR compatible fiber transceiver module that has been designed, programmed and tested to work with Arista Networks brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LR compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description | StarTech.com Arista Networks SFP-10G-LR Compatible SFP+ Module, 10GBASE-LR, 10GbE Single Mode Fiber SMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC 10km, 1310nm, DDM, Mini GBIC SFP+ - Lifetime Warranty (AR-SFP-10G-LR-ST) - SFP+ transceiver module - 10 GigE | Device Type | SFP+ transceiver module - LC single-mode | Form Factor | Plug-in module | Cabling Type | 10GBase-LR | Data Transfer Rate | 10 Gbps | Optical Wave Length | 1310 nm | Data Link Protocol | 10 GigE | Max Transfer Distance | 10 km | OEM Manufacturer Equivalent Part Number | Arista Networks SFP-10G-LR | Dimensions (WxDxH) | 5.84 cm x 1.39 cm x 1.37 cm | Weight | 21 g | Manufacturer Warranty | Limited lifetime warranty |
General | |
Device Type | SFP+ transceiver module |
Networking | |
Connectivity Technology | Wired |
Features | Digital Diagnostics Monitoring (DDM) |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 10GBase-LR - LC single-mode female x 2 |
Miscellaneous | |
MTBF | 1,386,624,697 hours |
Compliant Standards | FCC, MSA |
Power | |
Power Consumption Operational | 1.3 Watt |
Dimensions & Weight | |
Width | 5.84 cm |
Depth | 1.39 cm |
Height | 1.37 cm |
Weight | 21 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 9 cm |
Shipping Depth | 11.5 cm |
Shipping Height | 3.1 cm |
Shipping Weight | 50 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
