The AR-SFP-1G-T-ST is an Arista Networks compatible copper transceiver module that has been designed, programmed and tested to work with Arista Networks brand switches and routers. It delivers dependable 1 GbE connectivity over copper cable, for 10/100/1000Base-TX compliant networks, with a maximum distance of up to 100 m (328 ft).
This SFP copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description | StarTech.com Arista Networks SFP-1G-T Compatible SFP Module, 1000BASE-T, SFP to RJ45 Cat6/Cat5e, 1GE Gigabit Ethernet SFP, RJ-45 (Copper) 100m, 1000Mbps Mini GBIC Transceiver SFP Module - Lifetime Warranty (AR-SFP-1G-T-ST) - SFP (mini-GBIC) transceiver module - GigE | Device Type | SFP (mini-GBIC) transceiver module - RJ-45 | Form Factor | Plug-in module | Cabling Type | 10Base-T, 100Base-TX, 1000Base-T | Data Transfer Rate | 1 Gbps | Data Link Protocol | GigE | Max Transfer Distance | 100 m | OEM Manufacturer Equivalent Part Number | Arista Networks SFP-1G-T | Dimensions (WxDxH) | 6.8 cm x 1.37 cm x 1.38 cm | Weight | 15 g | Manufacturer Warranty | Limited lifetime warranty |
General | |
Device Type | SFP (mini-GBIC) transceiver module |
Networking | |
Connectivity Technology | Wired |
Features | Full duplex mode |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 1000Base-T - RJ-45 female |
Miscellaneous | |
MTBF | 510,469,759 hours |
Compliant Standards | FCC, RoHS, REACH, MSA |
Dimensions & Weight | |
Width | 6.8 cm |
Depth | 1.37 cm |
Height | 1.38 cm |
Weight | 15 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 9 cm |
Shipping Depth | 11.5 cm |
Shipping Height | 3.1 cm |
Shipping Weight | 50 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
