StarTech.com Bi-Directional SATA IDE Adapter Converter
£11.67
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • A single, versatile adapter can be used to connect an IDE device to a SATA motherboard or vice-versa without any drivers or software installation
  • Supports not only hard drives, but CD/DVD optical drives as well
  • Stock Status: In Stock
Product codes
The PATA2SATA3 is a bi-directional SATA IDE adapter/converter that lets you connect a Serial ATA drive to a legacy IDE port, or an IDE drive to a SATA motherboard port.
A cost-effective solution for upgrading existing IDE systems to support SATA hard drives or optical drives, the SATA/IDE adapter eliminates the expense of having to purchase a controller card while saving the expansion slot that would be required for card installation.
In addition to SATA hard drive installation, the adapter can be reversed in order to connect older IDE drives to a newer SATA-enabled motherboard, making it easy to retrieve old files from a previous system.
StarTech Advantage
  • Backed by a StarTech.com 1 year warranty and free lifetime technical support
Product Description StarTech.com Bi-Directional SATA IDE Adapter Converter - storage controller - SATA 1.5Gb/s - Ultra ATA/133
Device Type Storage controller
Bus Type Ultra ATA/133
Colour Black
Interface SATA 1.5Gb/s
Data Transfer Rate 1.5 Gbit/s
Supported Devices Hard drive, CD drive, DVD drive
Channel Qty 1
Max Storage Devices Qty 1
Product Material Plastic
Dimensions (WxDxH) 5 cm x 6.1 cm x 1.1 cm
Weight 170 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Bi-Direct...
£11.67
