StarTech.com Black Micro USB to Apple 8-pin Lightning Connect...
StarTech.com Black Micro USB to Apple 8-pin Lightning Connector Adapter for iPhone / iPod / iPad
£15.85
Colours:
18 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Lightweight, portable design, suitable for carrying as a laptop, iPad or iPhone accessory
  • No incorrect way of plugging the connector into your mobile device
  • Length: 10.15cm
  • Stock Status: In Stock
Product codes
Charge or Sync your iPhone, iPod, or iPad using a Micro USB cable. The USBUBLTB Lightning to Micro USB dongle for iPhone, iPod, iPad is colored to suit black mobile devices and provides a reliable solution for charging and syncing your Apple mobile digital devices using a Micro USB cable.
The dongle offers approximately 4-inches in cable length, which lessens strain on the connector port and prevents damage to the cable, while also reducing the potential of blocking other nearby ports.
The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable adapter is Apple MFi certified.
Product Description StarTech.com Black Micro USB to Lightning Adapter for iPhone iPod iPad - Lightning adapter - Lightning / USB - 10.15 cm
Cable Lightning adapter - Lightning / USB
Technology Shielded
American Wire Gauge (AWG) 24/28/32
Length 10.15 cm
Colour Black
Connector Lightning - male
Connector (Second End) Micro-USB Type B - female
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Black Mic...
£15.85
