StarTech.com Brocade 10G-SFPP-SR Compatible SFP+ MM Module -...
StarTech.com Brocade 10G-SFPP-SR Compatible SFP+ MM Module - 10GBase-SR
£42.00
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% Compatibility with Brocade 10G-SFPP-SR guaranteed
  • StarTech.com SFP+ modules are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and Multi-Source Agreement (MSA) industry standards
  • Stock Status: In Stock
Product codes
The 10G-SFPP-SR-ST is a Brocade 10G-SFPP-SR compatible fiber transceiver module that has been designed, programmed and tested to work with Brocade brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-SR compliant networks, with a maximum distance of up to 200 m (656 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com Brocade 10G-SFPP-SR Compatible SFP+ Module - SFP+ transceiver module - 10 GigE
Device Type SFP+ transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 10GBase-SR
Data Transfer Rate 10 Gbps
Optical Wave Length 850 nm
Data Link Protocol 10 GigE
Max Transfer Distance 200 m
OEM Manufacturer Equivalent Part Number Brocade 10G-SFPP-SR
Dimensions (WxDxH) 5.84 cm x 1.39 cm x 1.26 cm
Weight 20 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Brocade 1...
£42.00
