StarTech.com Cable Management Sleeve - 2 m
£10.47
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Organize your workstation cables with this adjustable cable manager, and trim the fabric to your desired length. This flexible and lightweight cable-management sleeve, made of polyester and nylon fabric, provides an easy and inexpensive solution to cable clutter. Use it to keep cables organized behind your computer monitor, while still providing access to cables when needed.
Simply open the rolled fabric to guide your cables through. The flexible sleeve automatically recoils to wrap around your cables. It can also expand to cover additional cables as needed. There are no tools required, and the cables do not need to be disconnected from the computer to be inserted into the cable-management sleeve.
Using sharp scissors, you can cut the cable-management sleeve to your desired length, to fit neatly under your desk or table, or behind your media center.
Product Description StarTech.com 6.5' (2m) Cable Management Sleeve/Wrap - Flexible Cable Manager - Expandable Coiled Cord Protector/Organizer - Trimmable (WKSTNCM) cable sleeving kit
Product Type Cable sleeving kit
Colour Black
Product Material Nylon, polyester
Dimensions (WxDxH) 2.5 cm 2.5 cm
Length 2 m
Weight 85 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Cable Man...
£10.47
