StarTech.com Cable Management Spine
£18.58
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Attractive cable-management spine adjusts and bends to keep cables organized and out of view
  • Routes cables from floor to desk to provide protection and strain relief
  • Four channels inside keep power or data cables separate
Product codes
This cable-management spine neatly routes cables from the floor to the bottom surface of your desk or table, with four separate channels for computer or electrical cords. It's an easy and practical way to protect your workstation cables, while creating an attractive, clutter-free work area.
The weighted base sits on the floor to provide a stable base to route your cables. You simply slide each cable through the slot into one of four channels within the cable manager, to keep cables organized and help prevent trips over cables on the floor.
The flexible cable management spine bends and moves, providing protection and strain relief for your cables. The cable manager features a modular design, with segments that snap together, allowing you to adjust the length to suit your needs.
The cable manager includes a mounting plate that attaches to the underside of your desk, table or counter. It keeps the cable management-spine securely in place.
StarTech.com Cable Management Spine - Flexible Cable Organizer - Cord Cover - cable organizer
Cable organizer
Placing / Mounting
Desk mountable
10.95 cm x 12.9 cm
Length
1.29 m
1.4 kg
Product Material
Plastic, steel
Silver
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Cable Man...
£18.58
