StarTech.com Ceiling TV Mount - Long Pole
£122.88
Delivery:
Key features
  • Save space by suspending your 32" to 75" flat-screen TV from the ceiling
  • Long pole with min-max length extension of 8.2 to 9.8' (2.5 to 3 m) for versatile use
  • Ceiling TV mount swivels +60 /-60 degrees to adjust to sloped or level ceilings
  • Full-motion mount lets you swivel the display +180 /-180 degrees around the pole and tilt downwards -25 degrees, without using tools
  • Durable steel mount supports TVs up to 110 lb.(50 kg)
  • Easy setup, with a hook-and-mount design
Product codes
Securely mount your flat-panel TV to a ceiling or overhead structure, and customize your viewing angle with easy position adjustments. Now, you can suspend your flat-screen television in an area with a high ceiling, for optimal viewing. This flat-screen TV ceiling mount supports VESA mount compatible TVs from 32" to 70" in size. It features a long pole that extends from 8.2 to 9.84 ft. (2.5 to 3 m), making it easy to adjust the distance from the ceiling. Its full-motion design lets you change your screen position and angle.
The ceiling TV mount lets you mount your flat-panel LCD, LED or plasma TV in a prominent area. It's ideal for use in lobbies, entrances or other areas with high ceilings.
The heavy-duty steel TV ceiling mount is compatible with a wide selection of TVs, able to securely support a 32" to 70" display, with a weight capacity of up to 110 lb. (50 kg). To keep the cables concealed and organized, you simply run them through the cable management channel inside of the pole, exiting near the top.
With an adjustable length, the telescopic-style pole makes it easy to mount your display at the desired distance from the ceiling and works well with a range of ceiling heights. The robust steel pole can extend from 8.2 to 9.84 ft. (2.5 to 3 m), with a total lift (height extension) of 19.6" (.5 m).
The flat-screen TV ceiling mount is designed to accommodate a wide variety of ceiling types. The ceiling mount swivels, so you can adjust the mount to work with virtually any type of ceiling for level viewing, including sloped ceilings (up to 60°), and pitched or horizontal (flat) ceilings.
You can adjust your flat-screen TV to create a comfortable viewing angle, by tilting it (up to -25°) down towards your audience for optimum visibility. The full-motion mount lets you swivel your display around the pole + 180° / - 180°, without using tools, which makes it easy to set up for viewing from any direction you choose.
The hook-and-mount design of the TV ceiling mount makes setup fast and easy. You simply attach the vertical brackets, with built-in hooks, to the back of your TV. Once the brackets are attached, you can hang your TV securely onto the ceiling mount. The preset leveling adjustments ensure ideal positioning after hanging.
Product Description StarTech.com Ceiling TV Mount - 8.2' to 9.8' Long Pole - Full Motion - Supports Displays 32" to 75" - For VESA Mount Compatible TVs (FPCEILPTBLP) - ceiling mount
Product Type Ceiling mount - ceiling mountable
Dimensions (WxDxH) 43.5 cm x 68 cm x 3.218 cm
Adjustable Height 250-300 cm
Tilt 0° to 25°
Pan -180° to 180°
Lift 50 cm
Rotation 360°
Adjustments Height, pan, tilt, swivel, rotation
Weight 10 kg
Recommended Use Plasma / LCD / TV
Recommended Display Size 32"-70"
VESA Mounting Interface 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Load Weight 50 kg
Material Heavy duty steel
Colour Black
Package Content 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 4 x washers, 8 x spacers (small), 4 x concrete anchors, hex key, 4 x M8x50 screws, 8 x spacers (big), wrench, 4 x nuts, 4 x screws, 4 x rectangular washers, ceiling mount and pole, middle pole, lower pole, TV mount, 2 x vertical brackets, horizontal bracket, 2 x M8x55 screws, 2 x M8x60 screws, mounting template
Manufacturer Warranty 5-year warranty
Designed For P/N: HDMIPLATE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Ceiling T...
£122.88
