StarTech.com Ceiling TV Mount - Steel
£110.98
Delivery:
Standard: 1-3 working days
Key features
  • Save space by suspending your 32 to 75" flat-screen TV from the ceiling
  • Min-max pole length extension of 22.0" to 35.8" (560 to 910 mm)
  • Ceiling TV mount swivels +60 /-60 degrees to adjust to sloped or level ceilings
  • Full-motion mount lets you swivel the display +180 /-180 degrees around the pole and tilt downwards -25 degrees, without using tools
  • Durable steel mount supports TVs up to 110 lb.(50 kg)
  • Easy setup, with a hook-and-mount design
  • Stock Status: In Stock
Product codes
Securely mount your flat-panel TV to a ceiling or overhead structure, and customize your viewing angle with easy position adjustments. Save space and create the ultimate viewing environment for your flat-screen television, by suspending it from the ceiling. This flat-screen TV ceiling mount supports VESA mount compatible TVs 37" to 70" in size. For maximum viewing versatility, the ceiling mount makes it easy to adjust the distance from the ceiling and offers a full-motion design that lets you change your screen position and angle.
The ceiling TV mount lets you mount your flat-panel LCD, LED or plasma TV in a prominent and comfortable viewing area while saving wall, desk and floor space. It's ideal for use in corporate boardrooms, hotel lobbies, restaurants, bars and meeting spaces.
The heavy-duty steel TV ceiling mount is compatible with a wide selection of TVs, able to securely support a 37 to 70" display, with a weight capacity of up to 110 lb. (50 kg). To keep the cables concealed and organized, you simply run the cables through the cable management channel inside of the pole, exiting near the top.
With an adjustable pole length, the telescopic-style pole makes it easy to mount your display at the desired distance from the ceiling and works well with a range of ceiling heights. The robust steel pole can extend from a minimum of 22" to 35.8" (560 mm to 910 mm) at maximum length, with a total lift (height extension) of 13.7" (350 mm).
The flat-screen TV ceiling mount is designed to accommodate a wide variety of ceiling types. The ceiling mount swivels, so you can adjust the mount to work with virtually any type of ceiling for level viewing, including sloped ceilings (up to 60°), and pitched or horizontal (flat) ceilings. The extension pole also swivels + 180° / - 180° for optimum viewing.
You can adjust your flat-screen TV to create a comfortable viewing angle, by tilting it (up to -25°) down towards your audience for optimum visibility. The full-motion mount lets you tilt or swivel your display around the pole, without using tools. The ceiling mount also features a 360° pan, which makes it easy to set up for viewing from any direction you choose.
The hook-and-mount design of the TV ceiling mount makes setup fast and easy. You simply attach the vertical brackets, with built-in hooks, to the back of your TV. Once the brackets are attached, you can hang your TV securely onto the ceiling mount. The preset leveling adjustments ensure ideal positioning after hanging.
Product Description StarTech.com Ceiling TV Mount - 1.8' to 3' Short Pole - Full Motion - Supports Displays 32" to 75" - For VESA Mount Compatible TVs (FPCEILPTBSP) - ceiling mount
Product Type Ceiling mount - ceiling mountable
Dimensions (WxDxH) 43.5 cm x 68 cm x 1.128 m
Adjustable Height 56-91 cm
Tilt 0° to 25°
Pan -180° to 180°
Lift 35 cm
Rotation 360°
Adjustments Height, pan, tilt, swivel, rotation
Recommended Use Plasma / LCD / TV
Recommended Display Size 37"-75"
VESA Mounting Interface 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Load Weight 50 kg
Material Heavy duty steel
Colour Black
Package Content Mounting hardware
Manufacturer Warranty 5-year warranty
Designed For P/N: HDMIPLATE
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Ceiling T...
£110.98
