StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver M...
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC w/ DDM – 550m (Mini-GBIC)
£51.76
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with Cisco SFP-GE-S guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and Multi-Source Agreement (MSA) industry standards
  • Type: Modules
  • Stock Status: In Stock
Product codes
Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPGESST Cisco Compatible Gigabit Fiber SFP Transceiver Module MM LC - 550m (1804 ft) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a Multimode LC port on your Gigabit fiber networking equipment or fiber media converter.
Supporting data rates up to 1.25 Gbps as well as Digital Diagnostics Monitoring (DDM), this LC SFP/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 850nm multi-mode SFP module is compatible with the Cisco SFP-GE-S transceiver.
Product Description StarTech.com Cisco SFP-GE-S Compatible SFP Module - Lifetime Warranty - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 1000Base-SX
Optical Wave Length 850 nm
Data Link Protocol GigE
Max Transfer Distance 550 m
Dimensions (WxDxH) 1.2 cm x 6 cm x 1 cm
Weight 17 g
Designed For P/N: PEX1000SFP2
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Cisco Com...
£51.76
