StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver M...
StarTech.com Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC w/ DDM – 20 km (Mini-GBIC)
£49.24
48 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with Cisco GLC-LH-SMD guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and Multi-Source Agreement (MSA) industry standards
  • Type: Modules
  • Stock Status: In Stock
Product codes
Add, replace or upgrade SFP modules on Gigabit fiber equipment. The SFPG1320C Cisco Compatible Gigabit Fiber SFP Transceiver Module SM LC - 20 km (12.4 miles) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a Single-Mode LC port on your Gigabit fiber networking equipment or fiber media converter.
Supporting data rates up to 1.25 Gbps as well as Digital Diagnostics Monitoring (DDM), this LC SFP/Mini-GBIC module can be installed into any fiber networking device with an MSA or Cisco compliant SFP port. Delivering both convenience and scalability, this fiber transceiver is fully hot-pluggable, which enables you to install the module without interrupting network traffic or requiring a device reboot.
This 1310nm single-mode SFP module is compatible with Cisco equipment.
Product Description StarTech.com Cisco GLC-LH-SMD Compatible SFP Module - 1000BASE-LH - 1GE Gigabit Ethernet SFP 1GbE Single Mode Fiber SMF Optic Transceiver - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC single-mode
Form Factor Plug-in module
Cabling Type 1000Base-LH
Optical Wave Length 1310 nm
Data Link Protocol GigE
Max Transfer Distance 20 km
Dimensions (WxDxH) 0.9 cm x 6.5 cm x 1.4 cm
Weight 25 g
Designed For P/N: ET91000LCOAM, ET91000SFP2, ET91000SFP2C, IES101002SFP, IES101G2SFPW, IES101GP2SFW, MCM1110SFP, PEX1000SFP2
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Cisco Com...
£49.24
