StarTech.com Cisco Compatible Gigabit RJ45 Copper SFP Transce...
StarTech.com Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module - Mini-GBIC
£42.00
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with Cisco SFP-GE-T guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic set ups
  • Type: Modules
  • Stock Status: In Stock
Product codes
Add support for 1000 Mbps RJ45 copper Ethernet connections to networking equipment with spare SFP slots. The SFPC1110 Cisco Compatible Gigabit RJ45 Copper SFP Transceiver Module (Mini-GBIC) is built to comply with MSA (Multi-Sourcing Agreement) standards to offer a cost-effective way to add, replace or upgrade a copper Ethernet port on your 1000 Base-T networking equipment.
Featuring Digital Diagnostics Monitoring support and 1000 Mbps Auto-negotiation at distances up to 100m (330 feet), this Ethernet SFP module can be installed into any fiber networking devices with an MSA or Cisco compliant SFP port. Delivering convenience and scalability, this copper transceiver is fully hot-pluggable, allowing you to install the module without interrupting network traffic or requiring a device reboot. This SFP module is compatible with the Cisco SFP-GE-T transceiver.
Product Description StarTech.com Cisco SFP-GE-T Compatible SFP Module - 1000BASE-T - 10/100/1000 Mbps SFP to RJ45 Cat6/Cat5e Transceiver - 100m - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - RJ-45
Form Factor Plug-in module
Cabling Type 1000Base-TX
Data Transfer Rate 1 Gbps
Data Link Protocol GigE
Max Transfer Distance 100 m
Dimensions (WxDxH) 0.9 cm x 5.5 cm x 1.4 cm
Weight 25 g
Designed For P/N: MCM1110SFP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Cisco Com...
£42.00
