StarTech.com Cisco Compliant 10GBase-T SFP+ Transceiver Module
£600.22
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatible with Cisco switches and routers
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic set ups
  • Type: Transceiver
  • Stock Status: In Stock
Product codes
The SFP10GBTCST is a Cisco compatible copper transceiver module that has been designed, programmed and tested to work with Cisco brand switches and routers. It delivers dependable 10 GbE connectivity over copper cable, for 10GBASE-T compliant networks, with a maximum distance of up to 30 m (98.4 ft).
This SFP+ copper module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com Cisco Compatible SFP+ Module - TAA - Lifetime Warranty - SFP+ transceiver module - 10 GigE
Device Type SFP+ transceiver module - RJ-45
Form Factor Plug-in module
Cabling Type 10GBase-T
Data Transfer Rate 10 Gbps
Data Link Protocol 10 GigE
Max Transfer Distance 30 m
Dimensions (WxDxH) 1.34 cm x 6.98 cm x 1.38 cm
Weight 24.2 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Cisco Com...
£600.22
