StarTech.com Cisco GLC-SX-MMD SFP - MM
£49.12
29 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with Cisco GLC-SX-MMD guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and Multi-Source Agreement (MSA) industry standards
  • Stock Status: In Stock
Product codes
This StarTech.com Gigabit fiber SFP is engineered to deliver reliable network connections. Built to exacting specifications and fully tested to ensure maximum performance, this high-quality fiber transceiver module can be installed into Cisco switches and routers that support the GLC-SX-MMD transceiver module, as well as other major brands of networking equipment.
This 1000Base-SX SFP delivers Gigabit connectivity over multimode fiber cable, with a range of up to 550 m (1804 ft. ). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
Product Description StarTech.com Cisco GLC-SX-MMD Compatible SFP Module - Lifetime Warranty - SFP (mini-GBIC) transceiver module - GigE
Device Type SFP (mini-GBIC) transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 1000Base-SX
Data Transfer Rate 1.25 Gbps
Optical Wave Length 850 nm
Data Link Protocol GigE
Max Transfer Distance 550 m
OEM Manufacturer Equivalent Part Number Cisco GLC-SX-MMD
Dimensions (WxDxH) 1.37 cm x 5.66 cm x 1.25 cm
Weight 28 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Cisco GLC...
£49.12
