StarTech.com Cisco QSFP-40G-LR4 QSFP+ - SM
£1,419.22
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with Cisco QSFP-40G-LR4 guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and Multi-Source Agreement (MSA) industry standards
  • Stock Status: In Stock
Product codes
Count on powerful performance and cost-effective 40 Gigabit Ethernet connections over single-mode fiber with this QSFP+. This Cisco compatible 40GBase QSFP (Quad Small Form-Factor Pluggable) is engineered by StarTech.com to deliver what you want most in your network connections: reliable performance. Built to exacting specifications and fully tested to ensure maximum performance, you can install this high-quality fiber transceiver module into Cisco networking devices that support the Cisco QSFP-40G-LR4, as well as other major brands of networking equipment.
With powerful four-lane performance, this 40GBase-LR4 QSFP+ transceiver module delivers 40 Gigabit connectivity over single-mode fiber with an optical wavelength of 1270nm to 1330nm and a range of up to 10 km (6.2 mi.). It provides a dependable and cost-effective way to add, replace or upgrade the ports on your networking equipment.
This 40GBase-LR4 QSFP+ is manufactured by StarTech.com to meet or exceed OEM specifications and comply with the industry's MSA (Multi-Source Agreement) standards. Committed to the highest standards of quality, StarTech.com provides an extensive range of networking products including copper and fiber network cards, fiber media converters, Ethernet switches and wireless products.
The 40 Gigabit single-mode QSFP+ is engineered to the highest quality standards and is 100% Cisco compatible, equivalent to the Cisco QSFP-40G-LR4 optical transceiver. The StarTech.com QSFP+ transceiver module is configured and fully tested to ensure it works seamlessly with Cisco or other major brands of networking equipment.
You can be assured that the use of StarTech.com QSFP+ products should not affect the warranty protection of your networking equipment.
Delivering both convenience and scalability, this fiber QSFP+ transceiver is fully hot-pluggable, which enables you to install it without interrupting network traffic or having to reboot your equipment. It provides a versatile and cost-effective solution that's compatible with a range of 40 Gigabit networking devices.
Ideal for use in Cisco switches, routers and other networking equipment, the QSFP+ optical transceiver provides reliable performance, allowing you to expand your network to remote segments cost-effectively. The SM fiber transceiver module supports Digital Diagnostics Monitoring (DDM / DOM), a maximum distance of up to 10 km (6.2 mi.), and maximum data rates of up to 40Gbps.
Product Description StarTech.com Cisco QSFP-40G-LR4 Comp. QSFP+ Module - 40GBASE-LR4 - 40GE Gigabit Ethernet 40GbE Single Mode Fiber SMF Optic Transceiver - QSFP+ transceiver module - 40 Gigabit LAN
Device Type QSFP+ transceiver module - LC single-mode
Form Factor Plug-in module
Cabling Type 40GBase-LR4
Data Transfer Rate 40 Gbps
Optical Wave Length 1270-1330 nm
Data Link Protocol 40 Gigabit LAN
Max Transfer Distance 10 km
OEM Manufacturer Equivalent Part Number Cisco QSFP-40G-LR4
Dimensions (WxDxH) 1.84 cm x 7.2 cm x 0.85 cm
Weight 40 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Cisco QSF...
£1,419.22
