StarTech.com Citrix EW3B0000710 Compatible SFP+ MM Module - 1...
StarTech.com Citrix EW3B0000710 Compatible SFP+ MM Module - 10GBase-SR
£42.72
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% Compatibility with Citrix EW3B0000710 guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and Multi-Source Agreement (MSA) industry standards
  • Stock Status: In Stock
Product codes
The EW3B0000710-ST is a Citrix EW3B0000710 compatible fiber transceiver module that has been designed, programmed and tested to work with Citrix brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-SR compliant networks, with a maximum distance of up to 300 m (984 ft).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com Citrix EW3B0000710 Compatible SFP+ Module - SFP+ transceiver module - 10 GigE
Device Type SFP+ transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 10GBase-SR
Data Transfer Rate 10 Gbps
Optical Wave Length 850 nm
Data Link Protocol 10 GigE
Max Transfer Distance 300 m
OEM Manufacturer Equivalent Part Number Citrix EW3B0000710
Dimensions (WxDxH) 5.84 cm x 1.39 cm x 1.37 cm
Weight 20 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Citrix EW...
£42.72
