StarTech.com Citrix EW3Z0000586 Compatible SFP+ SM Module - 1...
StarTech.com Citrix EW3Z0000586 Compatible SFP+ SM Module - 10GBase-LR
£77.47
Delivery:
Key features
  • 100% Compatibility with Citrix EW3Z0000586 guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and Multi-Source Agreement (MSA) industry standards
Product codes
The EW3Z0000586-ST is a Citrix EW3Z0000586 compatible fiber transceiver module that has been designed, programmed and tested to work with Citrix brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10GBase-LR compliant networks, with a maximum distance of up to 10 km (6.2 mi).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com Citrix EW3Z0000586 Compatible SFP+ Module - SFP+ transceiver module - 10 GigE
Device Type SFP+ transceiver module - LC single-mode
Form Factor Plug-in module
Cabling Type 10GBase-LR
Data Transfer Rate 10 Gbps
Optical Wave Length 1310 nm
Data Link Protocol 10 GigE
Max Transfer Distance 10 km
OEM Manufacturer Equivalent Part Number Citrix EW3Z0000586
Dimensions (WxDxH) 5.84 cm x 1.39 cm x 1.37 cm
Weight 21 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Citrix EW...
£77.47
