StarTech.com Compact Black USB 2.0 to 10/100 Mbps Ethernet Ne...
StarTech.com Compact Black USB 2.0 to 10/100 Mbps Ethernet Network Adapter
£15.37
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Allows users to share peripherals, transfer files and share a connection to the Internet
  • Can be a valuable tool when sharing network resources
  • Easy installation and setup
  • Stock Status: In Stock
Product codes
Documents
Add a 10/100Mbps Ethernet port to a USB enabled computer system. This compact USB 2.0 to 10/100 Mbps Ethernet USB network adapter offers convenient Ethernet connectivity - simply connect the network adapter to an available USB 2.0 port on your laptop computer, then connect the adapter to the Ethernet network.
Providing full/half duplex operation on both 10Mbps or 100Mbps Ethernet connections, this USB 2.0 Ethernet adapter supports data transfer rates of up to 200Mbps, providing a fully integrated, cost-effective and reliable solution to notebook users requiring Ethernet connectivity.
Product Description StarTech.com USB To Ethernet Adapter - 10/100Mbps Ethernet - USB 2.0 - Black - USB Ethernet Adapter (USB2106S) - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Ports 10/100 Ethernet
Dimensions (WxDxH) 2.2 cm x 6.8 cm x 2.6 cm
Weight 22 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX
Data Link Protocol 10Mb LAN, 100Mb LAN
Data Transfer Rate 100 Mbps
Compliant Standards IEEE 802.3, IEEE 802.3u
Colour Black
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.6.x to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.5 - 10.14
Manufacturer Warranty 1-year warranty
Resources
The following resources are available for the StarTech.com Compact Black USB 2.0 to 10/100 Mbps Ethernet Network Adapter
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Compact B...
£15.37
