StarTech.com Compact HDMI to VGA Adapter Converter - Ideal fo...
StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops
£23.66
28 in stock
Delivery:
Standard: 1-3 working days
Key features
  • The easiest way to convert an HDMI signal to VGA. with hassle-free plug-and-play installation
  • Maximum portability, with a small form factor and no power adapter required
  • Ensured Chromebook compatibility with extensive testing in a wide range of applications
  • Stock Status: In Stock
Product codes
Connect an HDMI device/computer to a VGA monitor or projector, with this slim adapter ideal for laptops/Ultrabooks. The HD2VGAMICRO HDMI to VGA converter lets you connect an HDMI output from your Ultrabook, Chromebook or laptop computer to a VGA monitor or projector.
With no external power adapter required, and a small form factor design, this portable HDMI to VGA adapter is a great accessory to have on-hand in your laptop carrying case. Plus, this easy-to-use converter supports plug-and-play installation, which speeds up installation time eliminates hassle.
The converter delivers maximum video quality, with support for resolutions up to 1920x1200/1080p - a convenient solution for boosting productivity by extending your computer's desktop onto to a secondary monitor.
Product Description StarTech.com Compact HDMI to VGA Adapter Converter - Ideal for Chromebooks Ultrabooks & Laptops - 1920x1200/1080p - video adapter - HDMI / VGA - 4.5 cm
Cable Video adapter - HDMI / VGA
Max Output Resolution 1920 x 1200 - 60 Hz
Length 4.5 cm
Colour Black
Connector HDMI - male (input)
Connector (Second End) HD-15 (VGA) - female
Features Active adapter
Designed For P/N: DKT30CSDHPD3, SV211HDUC
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Compact H...
£23.66
