StarTech.com Component / VGA Video and Audio to HDMI Converte...
StarTech.com Component / VGA Video and Audio to HDMI Converter PC to HDMI 1920x1200
£92.53
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Delivers worry-free performance, with a 2-year warranty and free lifetime technical support
  • Eliminates equipment costs by providing an alternative to the device upgrades required for compatibility between a VGA or Component video output and an HD display
  • Ensures durability, with a rugged metal enclosure
  • Type: AV Sender
  • Stock Status: In Stock
Product codes
Connect your VGA or Component video source to an HDMI display. The VGA2HD2 Component/VGA to HDMI Video Converter offers seamless conversion from an analog VGA or Component video source, such as a Computer, DVR, or DVD player, to a digital HDMI output.
The converter helps reduce equipment costs by eliminating the need to upgrade individual analog components, by offering a solution that converts an analog video source (RGB/YPbPr) for use with a digital HDMI display.
This versatile analog-digital converter not only supports resolutions up to 1920x1200 including high-definition 1080p, but also enables you to convert and combine an analog RCA audio source into its digital HDMI output signal.
Product Description StarTech.com Component / VGA Video and Audio to HDMI Converter - PC to HDMI - video converter - black
Device Type Video converter
Interfaces 1 x audio line-in - RCA x 2 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI output - 19 pin HDMI Type A , 1 x component video input - RCA x 3 (on supplied cable)
Dimensions (WxDxH) 7.6 cm x 3 cm x 9.2 cm
Enclosure Colour Black
Localisation United States
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Component...
£92.53
