StarTech.com Composite and S-Video to HDMI Converter with Audio
£123.40
Delivery:
Standard: 1-3 working days
Key features
  • Functions with NTSC and PAL systems
  • PC/TV resolution selector switch for compatibility with many different displays
  • 50/60 Hz frame rate conversion
  • Plug and Play installation - no software/drivers required
  • Advance 3D motion adaptive de-interlace
  • 3D motion adaptive YNR/CNR noise reduction
  • Type: Signal Converter
  • Stock Status: In Stock
Product codes
Convert a Composite or S-Video Signal and the Accompanying Audio to HDMI?. The VID2HDCON Composite and S-Video to HDMI? Video Converter (with Audio) lets you connect an S-Video or Composite device, along with supporting 3.5mm audio, to your HDMI monitor or television. Equipped with convenient selector switches for easy configuration, the S-Video/Composite to HDMI converter is able to function with both NTSC and PAL systems, and offers support for output resolutions up to 1600x1200 (PC) or 1080p (TV) to seamlessly integrate with almost any display. The converter features an integrated 3.5mm audio connection that enables sending the output through a single HDMI cable to your destination display, avoiding the hassle of running a separate audio cable.
Product Description StarTech.com Composite and S-Video to HDMI Converter with Audio - video converter - black
Device Type Video converter
Max Resolution 1600 x 1200
Interfaces 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI output - 19 pin HDMI Type A
Dimensions (WxDxH) 16.3 cm x 16.5 cm x 3.4 cm
Enclosure Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Composite...
£123.40
