StarTech.com Conference Table Connectivity Box – HDMI / VGA /...
StarTech.com Conference Table Connectivity Box – HDMI / VGA / Mini DisplayPort to HDMI Output
£269.95
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Concealed table installation clears boardroom cable clutter
  • Enable boardroom connection compatibility with laptops and Ultrabooks
  • Single cable connection to your HDMI display
  • In-table installation
  • Automatic audio/video switching
  • Hideaway panel
  • Stock Status: In Stock
Product codes
Install an HDMI, VGA, mDP & Composite Audio/Video access panel into the surface of a table, and output to an HDMI display or projector, with a discreet hideaway design
The BOX4HDECP Automatic Conference Table Connectivity Box features a concealed, in-table design that lets you connect a VGA, Mini DisplayPort, HDMI or composite video source device to an HDMI display or projector.
When the video switch isn't in use, you can simply slide the stylish cover panel over the connectors, hiding them inside the table or podium surface. Convenient Accessibility Presenters can conveniently share content from their own device with the table top switch automatically converting any attached audio/video source device source into a single HDMI output.
The switch box also offers stylish integration into your modern boardroom or classroom with a discreet hideaway panel. For added convenience the BOX4HDECP features a USB charging port to charge your mobile device and an Ethernet pass-through port for Internet connectivity in boardrooms where Wi-Fi is not available.
Connectivity Options With support for different video inputs including: HDMI, VGA, Mini DisplayPort, and composite, the video switch ensures support for almost any laptop, Ultrabook or mobile device such as MacBook, Microsoft Surface Pro 2 & 3, and Lenovo X1. The switch panel even works with legacy audio/video devices such as DVD player, and supports the use of video adapters for your iPhone or iPad.
Collaborate Easily The A/V switch makes your large display accessible to any presenter's video source device, by installing directly into the surface of your table or podium, and automatically outputs the most recently connected video source. Plus, support for high-definition video resolutions up to 1920x1080 (1080p) ensures the quality of your presentation is maintained.
The BOX4HDECP is backed by a StarTech.com 2-year warranty, and free lifetime technical support.
Product Description StarTech.com Conference Table Connectivity Pop up Box with AV and Data Ports - HDMI, VGA, Component, MDP to HDMI Output (BOX4HDECP) - mounting plate
Product Type Mounting plate - HD-15, RCA X 2, RJ-45, mini-phone stereo 3.5 mm, RCA, HDMI, USB Type A, mini-DisplayPort
Package Content External power adapter
Dimensions (WxDxH) 17 cm x 10 cm x 10 cm
Weight 1.661 kg
Compliant Standards FCC, RoHS
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Conferenc...
£269.95
