StarTech.com Cubicle Monitor Hanger
£55.17
19 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Maximize the available work space on your employee's desk, by mounting the monitor on the cubicle wall. With these cubicle monitor hangers, you can free up desk space by mounting monitors on the partitions between office cubicles. Each hanger can hold a monitor of up to 30" at 20 lb. (9 kg), and it provides both tilt and height adjustments so that your employees can position their displays for maximum comfort.
Without monitors taking up valuable work space, your employees can work more comfortably. These hangers can help you create extra elbow room in smaller work environments such as call centers, freeing up space for additional hardware or physical tasks such as drafting or reading paper documents. They can also help keep employees' workstations tidy by reducing the amount of equipment on their desks.
The cubicle hangers also provide an easy way to clear cable clutter. They feature an integrated cable organizer that neatly tucks cables out of the way.
The monitor cubicle mount features easy-to-adjust height and tilt mechanisms to customize the positioning of displays. This helps you create ergonomic work spaces that match each employee's distinct needs. They can adjust the height of their monitors without disrupting their work: simply pull out the height-adjustment pin and slide the monitor to the desired height. The mount allows for 16" of height adjustment. Once they select the desired height, they can tilt their monitors to adjust their viewing angle.
For viewing longer pages or blocks of code without having to scroll down the screen, the cubicle LCD mount also supports simple landscape-to-portrait display rotation.
The monitor hanger can work with almost any cubicle size. It can fit over various wall sizes ranging from 1.5" to 5.5" in thickness and is recommended for wall heights ranging from 19" to 30" above the desk level. The maximum varies slightly by user height.
The hanger also has a discreet, low-profile design that won't interfere with shelves that are mounted on a cubicle wall or disturb co-workers who are working in an adjacent cubicle. Plus, it's designed to protect the top of the cubicle wall from scratches and marks.
The monitor mount provides fast and easy installations. Simply select the width, attach the monitor, hang it over the cubicle wall, adjust the height and route the cables.
There's no need to assemble multiple parts, and no need to clamp anything to a desk. The cubicle-wall monitor mount comes with virtually no assembly and can be set up and ready to use in no time.
Product Description StarTech.com Single-Monitor Mount - Cubicle Hanger - mounting kit
Product Type Mounting kit - wall-mountable
Mounting Components 2 rubber pads, 4 spacers, screws, hanging cubicle mount
Dimensions (WxDxH) 5.5 cm 46 cm
Adjustments Height, tilt, lift
Weight 750 g
Recommended Use Monitor
Recommended Display Size 30"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 9 kg
Material Plastic, aluminium, steel
Colour Black
Package Content 4 x M4x12 screws, 4 x M4x25 screws
Designed For P/N: ACCSMNT
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Cubicle M...
£55.17
