StarTech.com Cubicle Monitor Mount - With Micro-Adjustment -...
StarTech.com Cubicle Monitor Mount - With Micro-Adjustment - For up to 34
£62.30
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 34" CUBICLE MONITOR MOUNT: VESA 75x75mm/100x100mm compatible single monitor cubicle wall hanger supports displays up to 34 inch (17.6lb/8kg); Silver powder coated finish; 3" profile from cubicle wall
  • EASY MONITOR HEIGHT ADJUSTMENT: Total height adjustment range of 12.3" from the top of the office cubicle; Easy-to-use height adjustment hand lever for toolless adjustability across 9 preset levels
  • DISPLAY RANGE OF MOTION: Ergonomic hanging cubicle monitor bracket increases comfort & productivity with +/-10° tilt & swivel, 360° screen rotation (landscape/portrait); Tension adjustments tools incl
  • EASE OF INSTALLATION: Features quick release detachable VESA plate; Mounting hardware incl. for compatibility; Adjustable clamp supports cubicle wall thickness ranging from 2.5" (63mm) to 3.5" (89mm)
  • SCALABLE SOLUTION: Create multi-monitor computer workstations by using several cubicle monitor hangers; Micro-adjustment allows for precise flat panel alignment; Cable management for organized setup
Product codes
Free up valuable desk space in your cubicle workstation with this cubicle monitor mount. It lets you mount a monitor on your cubicle wall to keep your work area more organized, comfortable and productive.
The cubicle monitor hanger, made of steel with a metallic silver finish, securely supports a 17" to 34" VESA mount monitor, with a maximum weight of 17.6 lb. (8 kg).
The cubicle wall monitor mount helps you free up surface area in your workspace, and keeps cables neat with integrated cable management.
Adjust your screen height quickly, by pulling the lever while sliding the monitor to the desired height. Up to 12" of height adjustment accommodates a wide range of users.
For customized viewing, tilt your monitor +/-10 degrees and swivel +/-10 degrees. The cubicle monitor mount also rotates +/-180 degrees, for landscape or portrait positioning.
Customize your work area by hanging multiple monitors, using several cubicle monitor hangers to create a multi-monitor workstation. The micro-adjustment feature lets you align your monitors in perfect unison. Plus, angle your monitors for optimum viewing.
The cubicle-wall monitor mount is easy to set up. The monitor mount works in most cubicles, with wall sizes from 1.5" to 3.5" in thickness. It's optimized for wall heights ranging from 19" to 30" above the desk surface.
Product Description StarTech.com Cubicle Monitor Mount, Cubicle Wall Single Monitor Hanger, Up to 34" VESA Mount Display, Height Adjustable Ergonomic Office Cubicle Hanging Flat Panel Hook & Clamp Bracket - Landscape/Portrait (ARMCBCLB) - bracket - for Monitor - silver
Product Type Bracket - wall-mountable
Tilt -10° to 10°
Rotation -180° to 180°
Swivel -10° to 10°
Adjustments Height, tilt, rotation
Recommended Use Monitor
Recommended Display Size 17"-34"
VESA Mounting Interface VESA
Max Load Weight 8 kg
Material Plastic, steel
Colour Silver
Package Content 4 x M4x12 screws, 4 x washers, 4 x M5x12 screws, hex key, 4 x M4x16 screws, 4 x spacers, EVA pad, 4 x M5x16 screws
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£62.30
