StarTech.com Dell EMC SFP-10G-SR Compatible SFP+ MM Module
£131.10
Delivery:
Standard: 1-3 working days
Key features
  • 100% Compatibility with Dell EMC SFP-10G-SR guaranteed
  • StarTech.com SFP modules are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and Multi-Source Agreement (MSA) industry standards
Product codes
The SFP10GSREMST is a Dell EMC SFP-10G-SR compatible fiber transceiver module that has been designed, programmed and tested to work with Dell EMC brand switches and routers. It delivers dependable 10 GbE connectivity over fiber cable, for 10Gbase-SR compliant networks, with a maximum distance of up to 400 m (1312 ft.).
This SFP+ fiber module is hot-swappable, making upgrades and replacements seamless by minimizing network disruptions.
StarTech.com offers a wide variety of SFP modules and direct-attach SFP cables, providing the convenience and reliability you need to ensure dependable network performance.
Product Description StarTech.com Dell EMC SFP-10G-SR Compatible SFP+ Module, 10GBASE-SR, 10GbE Multimode Fiber MMF Optic Transceiver, 10GE Gigabit Ethernet SFP+, LC Connector, 400m, 850nm, DDM, Mini GBIC - Lifetime Warranty (SFP10GSREMST) - SFP+ transceiver module - 10 GigE
Device Type SFP+ transceiver module - LC multi-mode
Form Factor Plug-in module
Cabling Type 10GBase-SR
Data Transfer Rate 10 Gbps
Optical Wave Length 850 nm
Data Link Protocol 10 GigE
Max Transfer Distance 400 m
OEM Manufacturer Equivalent Part Number Dell EMC SFP-10G-SR
Dimensions (WxDxH) 5.84 cm x 1.39 cm x 1.26 cm
Weight 30 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£131.10
