StarTech.com Desk-Mount Dual-Monitor Arm
£101.38
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Save space by mounting two monitors up to 27” onto a single base (max. weight 17.6 lb. / 8 kg)
  • Keep monitors aligned with micro-adjustment
  • Work comfortably with adjustable height, +/- 30°tilt, +/- 30°swivel and 360° rotation
  • Accessory Type: Mount
Product codes
This deskmount dual-monitor arm lets you mount two 13" to 27" VESA mount monitors, each weighing up to 17.6 lb. (8 kg), onto a single low-profile base. It gives you flexible desk-clamp or grommet-hole mounting, letting you save space while creating an ergonomic workspace in any office environment.
With a stable dual-arm design, the double-monitor mount lets you create more usable work space by mounting your monitors side by side on a single base. The screen mount features a flat low-profile back that lets you position your displays against a wall or cubicle wall.
The computer monitor desk mount features adjustable height along the pole. The smooth +/- 30° tilt motion and +/- 30° swivel make it easy to find the optimal viewing angle. You can also rotate your display 360° for portrait or landscape viewing, and make sure your displays are perfectly aligned using the micro-adjustment knob.
The dual-monitor arm is easy to install, with the desk-clamp or grommet mount (hardware included). Integrated cable management keeps your workspace organized. It works well with most desks, including sit-stand workstations.
Adding two monitors gives you the extra screen space you need to simplify multitasking and maximize your productivity.
Product Description StarTech.com Dual Monitor Mount - Supports Monitors 13" to 27" - Adjustable - Desk Clamp or Grommet-Hole Desk Mount for Dual VESA Monitors - Black (ARMBARDUOG) - stand - for 2 monitors - black
Product Type Stand - grommet, desk-mountable
Dimensions (WxDxH) 13.5 cm x 87 cm x 51.5 cm
Tilt -30° to 30°
Rotation 360°
Swivel -30° to 30°
Adjustments Height, tilt, swivel, rotation
Weight 4.9 kg
Recommended Use 2 monitors
Recommended Display Size 13"-27"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 8 kg
Material Plastic, aluminium, steel
Colour Black
Package Content 2 x VESA monitor mounts, hex key, 5 x rubber pads, desk clamp, column, 2 x end caps, 2 x cable-management clips (column), 2 x monitor arms, 2 x cable-management clips (monitor arm), 2 x end cap screws, hex key screwdriver, 8 x M4x14 screws, 8 x M5x14 screws, 8 x flat washers, grommet mounting adapter, grommet mount plate
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£101.38
