Save space with this premium desk mount monitor arm, by suspending your screen above your desk.
Product Description | StarTech.com Desk Mount Monitor Arm with 2x USB 3.0 ports, Pole Mount Full Motion Single Arm Monitor Mount up to 17.6lbs/8kg VESA Display, Ergonomic Articulating Monitor Arm, Clamp/Grommet - Small Footprint Design (ARMPIVOT2USB3) - mounting kit - for Monitor - black | Product Type | Mounting kit - desk-mountable | Mounting Components | Articulating arm, desk clamp mount, grommet clamp | Integrated Devices | 2-ports USB 3.0 hub | Dimensions (WxDxH) | 35 cm x 59.4 cm x 62 cm | Tilt | -90° to 90° | Rotation | -90° to 90° | Swivel | -90° to 90° | Adjustments | Height, tilt, swivel, rotation | Weight | 3.25 kg | Recommended Use | Monitor | Recommended Display Size | 17"-34" | VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm | Max Load Weight | 8 kg | Material | Heavy duty aluminium | Colour | Black | Package Content | 4 x M4x12 screws, 4 x washers, 4 x M5x12 screws, hex key (3mm), grommet plate, hex key (6mm), cable management clip, grommet screw | Manufacturer Warranty | 2-year warranty |
General | |
Width | 35 cm |
Depth | 59.4 cm |
Height | 62 cm |
Weight | 3.25 kg |
Colour | Black |
AV Furniture | |
Type | Mounting kit |
Placing / Mounting | Desk-mountable |
Cable Management | Integrated cable management |
Dimensions & Weight Details | |
Shipping Dimensions (WxDxH) / Weight | 43.5 cm x 24 cm x 11.7 cm / 4.15 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
