StarTech.com Desk Mount Monitor Arm - Steel
£46.24
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Desk-mount monitor arm supports displays up to 27” (685.8 mm) in size and 17.6 lb. (8 kg) in weight
  • Articulating arm lets you adjust your viewing angle with 180° swivel and + 45° / - 45° tilt
  • Arm extension up to 17” (428 mm)
Product codes
Free up desk space and position your monitor for comfortable viewing. Save valuable desk space and position your monitor in a more comfortable viewing position. This durable desk-mount monitor arm makes it easy to suspend your display above your work area. It features an articulating arm that enables you to tilt, swivel and rotate your screen, to create a more ergonomic workspace and enhance productivity.
The single-monitor mount enables you to free up desk space by raising your screen off of your desk. It gives you more room to work by removing the monitor's bulky base from your desk surface. It's a quick and cost-effective way to maximize your available desk space, which makes for a more comfortable workstation and a more productive work environment.
The articulating arm gives you maximum workspace flexibility. You can extend the arm up to 17" (428 mm), along with swivel (180 degrees) and tilt (up to 90 degrees) adjustments that make it easy to find the perfect viewing angle. The arm offers smooth 360-degree screen rotation, so it's easy to switch from landscape to portrait orientation, to best meet your work requirements. You can also adjust the height of your monitor along the pole to your desired viewing position, to a maximum height of 17.7" (450 mm).
With its heavy-duty solid steel construction, the monitor mount provides long-lasting performance. The monitor arm supports a flat-panel display 13" to 27" (330 to 685.8 mm) in size and up to 17.6 lb. (8 kg) in weight.
The single-monitor arm makes it easy to mount your VESA mount compatible display above your desk, table or other surfaces, using the included C-clamp or grommet mount. For easier mounting, the VESA mount features notches that let you pre-set the mounting screw, then slide the monitor in place and tighten the screw. To help keep your work area free of clutter, the monitor arm also features cable clips that keep your cables neatly out of sight.
StarTech.com Desk-Mount Monitor Arm - Articulating Arm - Heavy Duty Steel - adjustable arm
Adjustable arm
Tilt
-45° to 45°
Pan
180°
Lift
42.8 cm
Rotation
360°
Adjustments
Height, pan, rotation
Recommended Use
LCD display
Recommended Display Size
27"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Desk Moun...
£46.24
