StarTech.com Desktop Monitor Stand with Cable Hook - Mounting...
StarTech.com Desktop Monitor Stand with Cable Hook - Mounting Kit
£88.88
Delivery:
Standard: 1-3 working days
Key features
  • Mount a VESA (75x75, 100x100) compatible display 12" to 34", flat screen, curved or ultrawide, with a max weight of 30.9 lb. (14 kg)
  • Includes hardware for mounting an iMac or Apple Cinema Display
  • Landscape-to-portrait display rotation (for use in portrait position, the mount supports ultrawide displays with max width of 25.5"/64.8 cm)
  • Height adjustable monitor stand with 15" (380mm) tall support post plus position/viewing angle adjustments
  • Mounting bracket pans 60° around the support post
  • Accessory Type: Stand
  • Stock Status: In Stock
Product codes
Place a display, up to 30" in size, at your desk, using this height-adjustable monitor mount with integrated cable management. The adjustable monitor stand lets you mount a display on your desk, with tilt, pivot and height adjustments for perfect positioning. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The monitor stand holds most common displays with ease, supporting monitors from 12 - 30" up to a maximum weight capacity of 30lbs (14kg). For added flexibility, the included hardware can be used to mount your Apple iMac or Apple Cinema Display.
The desktop monitor stand features a 15in (380mm) tall support post, for a much greater range of height adjustments than typical monitor stands can provide. For viewing longer pages or blocks of code without scrolling, the LCD stand also supports landscape to portrait display rotation.
Adjust your display height, position and viewing angles easily to create an ergonomic work environment, with the added benefit of reclaiming valuable workspace on your desk by mounting on a support post above the desk surface.
Product Description StarTech.com Single Monitor Stand - Adjustable - Supports Monitors 12" to 34" - Premium - Single Screen VESA Monitor Mount Stand - Silver (ARMPIVSTND) - mounting kit
Product Type Mounting kit
Mounting Components Desk stand, feet, wrench, screws, cable clip
Adjustments Pan, tilt
Weight 3.3 kg
Recommended Use LCD display
Recommended Display Size 12"-30"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 14 kg
Material Plastic, steel
Colour Silver
Manufacturer Warranty 5-year warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Desktop M...
£88.88
