StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to...
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200
£20.90
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Save upgrade costs by connecting your DisplayPort computer to a VGA projector or monitor
  • Hassle-free setup with no software or drivers required
Product codes
Connect a DisplayPort 1.2-equipped computer to a VGA Monitor or Projector. The DP2VGA3 DisplayPort 1.2 to VGA adapter lets you connect your DisplayPort-equipped desktop or laptop computer to a VGA monitor or projector, eliminating the expense of upgrading to a DisplayPort 1.2-capable display.
The DP to VGA adapter is fully compliant with the DisplayPort 1.2 revision, ensuring compatibility with newer DisplayPort enabled computer systems. The DisplayPort 1.2 adapter is also backward compatible with older DisplayPort revisions, ensuring this adapter will work with your DisplayPort computer. Plus, with support for resolutions up to 1920x1200 / 1080p you can convert your DisplayPort video source to work with your VGA projector or display without sacrificing video quality.
For a hassle-free setup the DisplayPort adapter allows for plug and play installation with no software or drivers required.
Product Description StarTech.com DisplayPort to VGA Adapter Converter - DP to VGA - display adapter - 10 cm
Type Display adapter
Features Active cable (signal regeneration)
Length 10 cm
Connector DisplayPort - male
Connector (Second End) HD-15 (VGA) - female
Compliant Standards FCC, RoHS
Colour Black
Designed For P/N: MSTDP123DP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com DisplayPo...
£20.90
